Help identify a crankshaft.
sireland67
WV
I picked up some small block parts this weekend off a friend of mine.
In the lot of parts was an un-used crankshaft, it has stock 360 mains, and rod size, and looks to have a 4" stroke, as measured with a cheap set of 6" calipers.
The only makings is some stamped numbers:
7258
233
The crank was in a Scat box, but the numbers on the outside of the box were for Ford junk.
So anybody know who actually made this crank? I know it is a long shot.
Did you check scat's site? looks like a cast 4" stroke crank for a 360
I could not get the numbers to cross-referance anything on scats site, the box numbers did cross reference to a ford 460 crank.
I was just wondering about the dual flywheel pattern
6 are drilled, the other 6 are not.
I also though that was weird.
Its a new crank, but from which manufacture I cannot figure out.
The 7258 stamp is part of the Mopar Performance number P5007258. It’s a 4” cast mopar performance crankshaft
