Ok, sorry, I was a member before but my account went poof!! It's a 225 and the leak is where the two manifold bolt togeather under the carb between the tin gasket. I have no leak at the head. The metal gasket is very thin, doesent someone make a reguluar composet gasket?
thx Ted
I'll more than likely get flamed but this works..... get a new set of gaskets, use the high temp RTV on the gaskets, torque to specs, clean around mating surfaces so no one will make fun of you. I've seen this done and it works.... works on leaky headers also. Don't need to whole lot.
