The original bulbs were 2 filiment bulbs ( 1157 ). Consider what a single filiment bulb would do in the same place.. Blinks with turn but send the park signal to the same filliment and now it getting both constant amd flashing current. You wouldn't see the flashing current. The 1157 produces 2 different levels of light too so when both are on you can see the difference.
I dont know anything about the LEDs . I would like to know if both turn indicaters on your inst' panel come on with the park lamps.
Good luck in any case.
Oh and by the way... make dang sure you have proper brake lights.
