Dart360Custom
Member
except the starter selonoid but power inside the car and ignition is off sometimes it will run fine then cut off others its dead any ideas guys i need to get this fixed quick :wack: btw it is my 69 dart
OldVart said:Do you still have the original wiring running through the factory ammeter? If so, that's one of the first places to start checking. Also, the firewall wiring connectors are a good second choice for problems of this nature. The big red wire in the upper right corner of the one firewall connector often burns out the connector inside the plastic housing so you really can't see it until you seperate the two halves. The main reason for this can often be related back to the original ammeter wiring.
I had much the same problem with my 66 for a while until I finally bypassed the ammeter then fixed the burned out connection in the bulkhead connector.
A couple of other causes could be a bad ignition switch ,or a faulty neutral safety switch on your transmission. Good luck.
