I would have to hear it run again, after all that work.
Stay away from the A41. I put one in my 70 dart 340 and got about 300 miles on it before it just let go. Don’t know if it’s the converter or transmission but it only had a one year warranty and it took me several years to get the car on the road so they would not help me at all.Yes I am. I'm going to work with this transmission and converter setup until I pull the trigger on the silversport a41 transmission next year.
Oh wow I can't believe it only lasted that long. How many years did you have the transmission before you got the car in the road?Stay away from the A41. I put one in my 70 dart 340 and got about 300 miles on it before it just let go. Don’t know if it’s the converter or transmission but it only had a one year warranty and it took me several years to get the car on the road so they would not help me at all.
Man I'm sorry to here that. I'm looking into the TKX full swap kit recentlyI bought the transmission in 2021 got the car on the road last fall. Put a new front suspension under it this spring and was driving the car to get the front end aligned and it went out. I haven’t pulled it yet will probably do it this winter.
Why were the "oil shields" not installed on engines with the drip tray? Did the crank seal not need any protection if the drip tray was used?It's not an oil slinger. That's been a myth that needs to have been busted for DECADES. It's an oil SHIELD to help keep oil directly OFF the front crank seal. That's its only purpose.
I've not paid enough attention to even notice that. With the modern seals that are on the market nowadays, the shields really are not even needed anymore.Why were the "oil shields" not installed on engines with the drip tray? Did the crank seal not need any protection if the drip tray was used?
Thanks. The reason I was asking is I'm building my short block right now. I was curious why my 360 had no oil slinger/shield but my 340 did.I've not paid enough attention to even notice that. With the modern seals that are on the market nowadays, the shields really are not even needed anymore.
Honestly, I think it was hit and miss. Maybe Karl @krazykuda will chime in. He worked the assembly line for a while.Thanks. The reason I was asking is I'm building my short block right now. I was curious why my 360 had no oil slinger/shield but my 340 did.
Just run one. They are cheap and even if they don't help, they can't hurt. (In my humble and often mistaken opinion.)Thanks. The reason I was asking is I'm building my short block right now. I was curious why my 360 had no oil slinger/shield but my 340 did.
