YoungBlood
Jolt the Squares
Since I’m still laid up at home, I have been doing a lot of reading and research, and only buying what parts will factually work. One little area that I’m getting some unclear info is Cylinder Heads.
I’m going to spare you guys that part of it, but basically my machine shop wants me to just buy Edelbrock Performer Aluminum heads and be better off that way.
My engine is a 72 318 2bbl Motor that appears to be like 180bhp and under 8.0:1 compression from the factory that I put a 4bbl and intake on and drove the piss out of for years.
I am rebuilding this engine (0.30“ overbore) and initially planned to freshen up these heads. I am going for reliability, and trying to keep everything around or under 275hp. I'm going to run the base Edelbrock Performer Intake and 600cfm carb. I want approx. 8.5 compresson.
All research leads me to believe that these 72 318 heads are 74cc chambered from the factory. Does this seem correct?
If so, theoretically, with these pistons…
http://www.hughesengines.com/Index/...Sk=&searchmode=partnumber&page=1&partid=10427
…they could instantly bump the motor up to 8.5:1 compression, without milling, correct?
Would installing 1.88/1.60 valves be a good, worthwhile idea?
I will be running a Comp HE260H Cam & Lifters.
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=618&sb=2
With that, I am going to run these pushrods…
http://www.compperformancegroupstor...tore_Code=CC&Screen=PROD&Product_Code=7958-16
…and these valve springs (recommended)
http://www.compperformancegroupstor...Store_Code=CC&Screen=PROD&Product_Code=901-16
Keeping my heads, getting a clean up, 3 angle valve job, and the 1.88/1.60 valves will run $640.
Buying the Edelbrock set up for that cam OOTB would be $1600+. That’s a lot of head for a very mild street 318, but I’m not opposed to it.
What would you* do?
*If you recommend Magnum heads, I appreciate that, but please don’t reply unless it‘s for recommending one of the two options mentioned. Thank you!
What would you* do?
