autoxcuda
- Joined
- Apr 6, 2007
- Messages
- 8,842
- Reaction score
- 3,801
Well after tossing the number #6 rod bearing two weeks ago in the only car I own that runs, my 68 Cuda, I ran into an issue.
I just found out the 340 block I got at Spring Fling has a rear main cap that will not clean up with an align hone.
Anyone in So Cal with some extra rear main cap(s) off a 340, 273, 318 pre magnum junk block?? Maybe one you use as a paperweight or door stop?
360 or magnum blocks have different rear main caps.
So Cal dudes, any local ideas?
Steve Wall
So Cal
Steve Wall
So Cal
