dustoff440
Just did a bunch of research, on 360 Magnums up to 96 the torque converter was balanced with weights, after 96 the balance was in weights on the flex plate. So if you want to run a neutral balance converter like I have that has no weights you will need the 97 and up weighted flex plate. If you dont have a weighted flex plate you will have to have weights installed on the torque converter. I'm hoping someone out there has one for a reasonable price.
