help need a steering coupler repair kit
silver fox
ottawa canada
Hey member's,can any one tell me where i can get a repair kit for the 73 duster i see them on e bay but i don't have pay pal & the one's i do see don't ship to canada thank's
Are you talking the rubber steering coupler disc?(4 in around,bolts tween the steering shaft flange,and the steering box flange?).Pull out your old one,look for a Dorman/Motormite replacement.They have 3 part numbers,one will fit.
wouldn't a 74 duster use this style? i do like that bail for holding together though..
if so i'd go with one of these
from steer and gear
Jim's Auto Parts sells all the parts you need to do a stock rebuild.
http://www.jimsautoparts.com/steering_parts.htm
Not sure if they sell them built already.
I think Mancini Racing might also carry stock style replacements - can't remember.
Or you can go aftermarket with a stainless U-joint style from Flaming River. That's what I did, but it required cutting the steering shaft (1/8" - 1/4" if I remember correctly)
I just rebuilt mine was sure it was from mopar performance. National moparts should have them also.
I would watch dealing with Jim's Auto Parts. I've had a couple bad deals from him. No need to go into detail here, but watch him..
FWIW, Dorman part number 425-253 (less than $8.00) appears to be exactly the same as what's being sold on ebay for $20-45. (Also the same as the base kit that Bouchillon or Steer and Gear is selling). The Dorman catalog lists it for vans. I bought one that I plan to install in my '69 C-Body. I've compared the parts. With the exception of the ID of shaft hole in the rubber seal, everything is identical. Heck, even the kit I bought off ebay years ago for my Duster had the orange seal with the hole smaller than original.
http://www.dormanproducts.com/p-26059-425-253.aspx
