71DartAugusta
Active Member
I am looking to add a sway bar and would like to know who has done this on a Dart with a SB V8 and clarify which parts will interchange with the following set up? This will be primarily used as a street car and the front brakes will be 73+ Disc BBP
I want to know if the late model style 72 and older LCA w/ tab & sway bar set up will interfere with the front mounted 73+ calipers? Or will I need to go with a 73+ LCA w/ tab, sway bar, and K frame set up to get the caliper clearance?
Thanks in advance!
Thanks in advance!
