Guys,
I am pulling out my engine to start the turbo project and do some engine bay work. I need some help on different areas. My car was an all motor 340 and it ran 10.90's with the current setup. I am keeping the long block but changing some things to try and make it more boost friendly. This is were my questions begin, whats the best way to reduce compression on these engines (without changing pistons or heads). Maybe use a cometic mls head gasket, use a dead copper felpro spacer? What options are out there? Will an adjustable timing sprocket set help? Like I said, I dont want to start changing internals yet. This is my first domestic turbo build ( actually my first 8 cyl ). Thanks.
Here is some info:
63cc head chambers
0 deck block
30 over bore
purple cam (Duration 284/284, Lift .528/.528)
Flat top pistons ( dont know cr )
202/160 valves
Here is some info:
63cc head chambers
0 deck block
30 over bore
202/160 valves
