TheTecher
Evan the jeeper.
I have been trying to get my motor in the car for some time. Its in but not straight, I had the wrong brackets on it for a while. Now I bought brackets from MoparGod and still the same thing. Here some pics
Engine brakets go behind the ears. Then it should drop right in.
Tried that, moved the driver to in front of the ears to try to help line it up. My tranny is not being held up, could that be my problem? It appears that the pass side is not far enough back, when i push the motor back to line up the mount with the hole the motor is not straight.
