twokeelya
Member
hello everyone. I finally got the new rear end in. However, the disk brake tab for the brake lines are directly in the way of the rear shock. is there a work around or do I have to cut the tab off and move it. If so, which direction should it go? I was wondering if I turned the spring perches around and switched sided of the shocks.
Thanks in advance
Thanks in advance
