Most times, yes, without issue.
You may have an issue with the backing plates bolt hole size and how wide they are.
A drill may be needed to modify the hole size.
Backing space may be different.
Tid bit, I put on 11 drums from a Cordoba onto the Dusters 8-1/4 previously equiped with 10 inch drums. Now I order rear shoes for a Cordoba (79) to avoid any problems.
