I have a 1969 GTS 340 4 speed car. Does the clutch rod going thru the firewall go bent end to Z bar or bent end to pedals?
Thanks in advance.
Thanks in advance.
The hole should be sorta oval,sorta oblong, but the downrod should be sorta centered in the window when correctly installed, and remain centered throughout the pedal travel. The thing that makes that happen is the lateral positioning of the outboard ball-stud and the fancy wire clip that locates the bushings inside the Z-bar tube. The inboard end just floats on the the ball/ bracket where ever.The hole thru the firewall that is oblong,
