pagilman Well-Known Member Joined Nov 19, 2005 Messages 790 Reaction score 5 Location farmingtonPa SilverSpr FL May 2, 2011 #1 Had this 904 rebuilt a couple years ago and never looked at it. When i pulled the plastic off of it the other day I see a hole near the shaft. Can someone tell me what goes in the hole? thanks Walt Attachments 100_0331 b.jpg 83.7 KB · Views: 104
4spdragtop FABO Gold Member FABO Gold Member Joined Aug 28, 2009 Messages 39,582 Reaction score 22,903 Location Ontario Parts Unknown May 2, 2011 #2 I think that is where your speedo cable mounts to
RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member Joined Jun 7, 2010 Messages 104,978 Reaction score 102,725 Location Georgia May 2, 2011 #3 Speedometer gear housing. I don't see a drive gear on the output shaft either. Kinda dark in there though.
67Dart273 Well-Known Member Joined Oct 14, 2010 Messages 60,035 Reaction score 33,299 Location Idaho May 2, 2011 #4 Read this thread: http://www.forabodiesonly.com/mopar/showthread.php?t=137442
pagilman Well-Known Member Joined Nov 19, 2005 Messages 790 Reaction score 5 Location farmingtonPa SilverSpr FL May 2, 2011 #5 Beautiful, thanks men for your inputs, Walt
D dartswinger 70 Member Joined Apr 30, 2011 Messages 16 Reaction score 0 Location tresckow,pa. May 2, 2011 #6 make sure you get the right gear that goes with the size of your rims.14 or 15 inch.
Tony Fields That's How I Roll Legendary Member Joined Aug 8, 2006 Messages 8,671 Reaction score 336 Location Columbus, Indiana 47201 May 2, 2011 #7 dartswinger70 said: make sure you get the right gear that goes with the size of your rims.14 or 15 inch. Click to expand... Speedo gear is based on tire diameter and gear ratio....not rim size. Attachments speedo 001.jpg 90.4 KB · Views: 82
RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member Joined Jun 7, 2010 Messages 104,978 Reaction score 102,725 Location Georgia May 2, 2011 #8 Thanks Tony. Great chart.
daredevil Well-Known Member Joined May 19, 2007 Messages 10,983 Reaction score 249 Location S/w Houston May 2, 2011 #9 Cant believe the rebuilder didnt clean things better. Looks almost used instead of rebuilt. Some dont take pride in their work.
