Yes took bulk head connector apart. It has been replaced in the past due to ammeter melting red wire. Previous owner did wire bypass for voltage gauge.ALSO when you checked power "at the bulkhead" OR ANY OTHER TEST...........it is IMPORTANT that you have a load you can apply.........like the headlights.......or even the dome/ courtesy lights. This is because, with everything shut off, there is no LOAD on the bad circuit, and a bad connection can "make" long enough to cause a "good" meter reading.
Have you had the bulkhead connector apart? NO!!!!???? What are you waiting for??
