sounds like a lot of confusion with ur timing, points,and wires,, number one,, if you have that big giant yello accell coil,,,after you get this running correctly,,get rid of that yellow coil,,,,they are known for breaking down prematurely,,,,
as for the 3 rear window trim pieces,,the pins that the nuts are on are SUPER FRAGILE,,, there is 5 trim pieces if the trunk hinges have the trim,,and hard to find in good condition,,,
first open trunk,,unscrew the trunk hinge trim covers if they are there,,,they are a right and a left they do not interchande side to side,,,
next,,open divider door from trunk to rear compartment of car,, lay in there looking up at the area inside that thr trim on the out side is,,, you will see round plastic caps,,pop them out with a small screw driver,,get a flash lite,, you will need a small socket,,i forget the size,,and a rachet or driver handle,, on the end pieces there are 2 nuts on each,, on the middle piece i think there are 4??? look out side to see which piece is over lapping which,,and remove the nuts inside in the proper order,, have some oen hold them while u inscrew the nuts,,they may fall fight of fthe car,,they are fragile,,,when reinstalling,, make sure those same nuts still fit,,, u may need to go get new smae style nuts,, and yes like sadi earlier dont drop them in the frame of the car you will never get the nuts out,,,
