68dart340
Member
In order to take my cluster bezel out to detail, I had to drop the steering column in the Dart. I hooked the cluster itself back up so I can still drive it while I paint my dash. Anyways, I took it for a drive the other day and it worked fine. I found out one of my brake lights was burnt out so I had my dad pushing the brake while I played with the light. I took it for another drive the next day and the brake pedal seems to stick. After you push it down it doesn't freely release itself and if it does it does so VERY slowly. There isn't any feel for the brakes either. Any ideas what it is?
