help
danial
Active Member
california
I cant find the drain plug for slant six coolant/water on engine want to hook up hose to intake and flush my engine I pulled this motor out of another car and it is over heating I have tried every thing. I removed what I think is the drain plug and not a lick of fluid on it VERY worried.
There is a drain plug on the rad. Not sure where one the block, but the one in your pic sure looks like one.
Pull that plug out you may have to stick a screw driver or something in it till it starts draining. They get kinda sludged up.
Just figured if it's older you might want to replace them they are cheap and it would make it easier to completely flush the motor
the screw driver worked thank you I was really worried .Thank you for your help.
