Help
CUDACOX
Innisfil, Ontario, Canada
Hi, Just wondering if anybody has advise on which street tires to buy that are nice and sticky,Hook -up good! What do you run? Thanks, Craig..
I either run GoodYear or BFG's....alot of guys started to go with Mickey Thompson's with more horsepower...(my stuff is mostly stock)
My Duster is mostly stock. 340 with 509 Purple shaft Cam,Shaved heads,700 Edlebrock carb, Torker 340 intake,Headders,with a 4 speed and 391 posi. The problem is right now I run 245/60R14" and can spin them alot with little traction. I bought a pair of 15" Ralleys SBP at Mopar Fest and need some Ideas on what to use. Thanks for the reply!! Craig.
Yes...255 60's will fill it up nicely....15-7inch wheel
Myself and several of my friends use Futura GLS tires. On the street, they hook good once you get them heated up.
I use a set of M/T 26x12.50 Sportsman Pro and sometimes a set of Goodyear 275-60 x15 and they both hook about equal.
