SRT_DSTRHOLC
thats kool, I dont care...These are real problems Im having.. First I was worried about the idle drop then while I was trying to fix that, this popping noise appeared.
Ok . Allow me to be brutally honest.
After three threads and having several members drop out because of frustration Including myself
You can not fix your car.
Call a tow truck. I will google one for your area if needed
Have your car towed to a shop and tell them this . "Fix it and call me when it's done."
This is the only way your car will run correctly.
Maybe ill just find someone local to help not a shop a local mopar guy
Painful reading your posts.
Take your car to a shop.
If this is the 4th set and you are still having the same problem, I would look somewhere else ... possibly a head gasket.
no its the 4th set because ive gone through 2 camshafts and 1 because I didnt seal it correct and this number 4 because I didnt seal it right and I know because its leaking ontothe timing cover.
Im using the edlbrocks because their port matches the ports on my intake and my heads
Ok, then perhaps it's not a head gasket issue.
:violent1: :tongue3:
Might be a wiped intake lobe on the camshaft causing the pop?
