Hemi 68 Dart/Barracuda Scoop question
knk-mopar-parts
Bowling Green, MO
I am wanting to know if the original LO23 & BO23 cars come with the scoop molded into the hood, or if the scoop was a bolt on deal? If so Anybody have any pics of original scoop underside?
Original Hood Scoop from Dave Wren's 1968 BO29 Super Stock Barracuda.
Molded 'one-piece' Fiberglass Hood w/Scoop with '2' Pedestal Supports to keep the Scoop
from lifting.
Factory Hood w/Scoop came thru with '4' corner hood pin latches.
Dave added the '2' additional outer-edge center pins.
The hood on my 67 barracuda is a nos super stock it weights 14 lbs and the aftermarket race hoods weight in at a very heavy 6-7 lbs. The hood that have had never been used it is a one oiece hood with a wooden frame molded in. If you want pics pm me and i can take pics of the top and bottom of the hood off the car
The 'proto-type' on the Test Mule Barracuda, was a Fiberglass Scoop 'riveted'
to a steel hood that was flash grounded.
