Hemi Alternator Wiring
New Hemi Engine Swaps
  1. thedartsport
    thedartsport Well-Known Member
    312
    161
    Nov 24, 2010
    Tennessee
    Local Time:
    3:49 AM
    Hey all, trying to figure out what I’m doing wrong with my alternator on my Hemi swapped Challenger. I used the old style external regulator and wired my exciter to it and one of the two wires coming from the plug on the alternator. 12 volts when the key is on. Then I wired the output to the battery, but it will not charge while running. Is there something about the new alternators I’m missing? I have a good ground at the regulator. I used the diagram attached in the pictures. Thanks!
  2. thedartsport
    312
    161
    Nov 24, 2010
    Tennessee
    Local Time:
    3:49 AM
    3B285019-3397-4356-8661-A4CA03D2F7BF.jpeg 66658C64-573C-4499-96EF-AAF5CA942C33.jpeg B92B1978-DB82-4550-A725-3A32C9D0C014.jpeg 289D977F-5E2C-48BE-AA7C-20BC3C8F72ED.jpeg 3B285019-3397-4356-8661-A4CA03D2F7BF.jpeg 66658C64-573C-4499-96EF-AAF5CA942C33.jpeg B92B1978-DB82-4550-A725-3A32C9D0C014.jpeg 289D977F-5E2C-48BE-AA7C-20BC3C8F72ED.jpeg
  3. tonysrt
    tonysrt FABO Gold Member FABO Gold Member
    925
    473
    Dec 25, 2016
    Northport, NY
    Local Time:
    4:49 AM
    Doesn't that alt. have a built in regulator?
  4. thedartsport
    312
    161
    Nov 24, 2010
    Tennessee
    Local Time:
    3:49 AM
    Negative. These were regulated by the computer from the factory.
  5. 408 swinger
    408 swinger FABO Gold Member FABO Gold Member
    2,403
    2231
    Nov 12, 2010
    Iowa
    Local Time:
    3:49 AM
    Pre-Eagle or Eagle? The 08 older alternators will work. The Eagle alternators won't work that way. They are controlled Waaaay different than the early ones. They are both regulated through the PCM, but, the early ones you can control via the old regulator. Bouchillon has a write up on their site.
    • Like Like x 1
    • Agree Agree x 1
    • 67Dart273
      67Dart273 FABO Gold Member FABO Gold Member
      48,788
      16931
      Oct 14, 2010
      Idaho
      Local Time:
      1:49 AM
      You are going to have to send a link because I see nothing over there. I was under the impression that the newer Magnum/ hemi alternators were still isolated field just like 70/ later Mopar back in the day
    • 408 swinger
      2,403
      2231
      Nov 12, 2010
      Iowa
      Local Time:
      3:49 AM
      • Agree Agree x 1
      • thedartsport
        312
        161
        Nov 24, 2010
        Tennessee
        Local Time:
        3:49 AM
        Pre Eagle. It’s a 2006. I put a ground to the green field wire and the alternator started charging, so I’m thinking it’s a bad regulator now.
        • Agree Agree x 1
        • 67Dart273
          48,788
          16931
          Oct 14, 2010
          Idaho
          Local Time:
          1:49 AM
          Is the regulator FOR SURE grounded? That mount looks a bit rusty.
          • Agree Agree x 1
          • thedartsport
            312
            161
            Nov 24, 2010
            Tennessee
            Local Time:
            3:49 AM
            Yes it’s got a good ground. Even ran a jumper wire straight from the negative battery post to ground it and nothing changed.
          • loganscuda
            loganscuda DON’T reMember
            2,486
            2639
            Jul 15, 2010
            san antonio
            Local Time:
            3:49 AM
            I have an 05 and do not use a regulator.
          • 408 swinger
            2,403
            2231
            Nov 12, 2010
            Iowa
            Local Time:
            3:49 AM
            I wonder if the op has carb'd his.
            • Agree Agree x 1
            • Kiddart1
              Kiddart1 Well-Known Member
              155
              63
              Aug 27, 2008
              Macomb Michigan
              Local Time:
              4:49 AM
              I had to swap the wires on the plug for mine to charge, it was weird but she charges great now.
              • Like Like x 1
              • thedartsport
                312
                161
                Nov 24, 2010
                Tennessee
                Local Time:
                3:49 AM
                Ended up being a bad voltage regulator out of the box. Tried another one I knew worked, and it’s been charging ever since. Thanks all.
                • Like Like x 2
                • tonysrt
                  925
                  473
                  Dec 25, 2016
                  Northport, NY
                  Local Time:
                  4:49 AM
                  Could it be your 05 Alt. came from a different vehicle? At this point in time with things changing so rapidly who knows what works and what doesn't work.
