Hemi Remote Oil Lines
Boony405hp
Brisbane, Australia
Does anybody know the exact size and type (assume NPT) the threads are for the remote oil lines on the new hemi blocks?
Cheers, Dave.
I found the NPT fittings I originally used were borderline not long enough. They threaded so deep that the flats started hitting the block. I almost think they might be an ORB (o-ring boss) fitting since it looks like there's a bit of a counterbore on the top of them. Either that or I just needed longer fittings. I guess they just used a standard hex head plug though, so they probably are NPT and I just needed a longer fitting.
I have noticed a few guys have said they are running 1/2 or -8AN lines for their remote oil filter setups. Is there any benefit to this? Wouldn't the flow be limited by the smallest point ie. the 3/8's (-6 AN) connection on the block so there would be no advantage in running a bigger line?
Here is what I am looking at ordering (I have based my order on others using -8AN line), from Engine block to remote oil filter: If I have missed anything, feel free to chime in as I've never ordered anything with these fittings.....
1. Fitting, Straight, -8 AN Male to 3/8 in. NPT Male, Aluminum, Blue Anodized, Each (QTY:2)
EAR-981608ERL
http://www.summitracing.com/int/parts/ear-981608erl/overview/
2. Fitting, Hose End, Swivel-Seal, Straight, -8 AN Hose to Female -8 AN, Aluminum, Red/Blue, Each (QTY:4)
EAR-800108ERL
http://www.summitracing.com/int/parts/ear-800108erl/overview/
3. Fitting, Straight, -8 AN Male to 1/2 in. NPT Male, Aluminum, Blue Anodized, Each (QTY:2)
EAR-981688ERL
http://www.summitracing.com/int/parts/ear-981688erl/overview/
4. To 1/2 NPT Trans Dapt. Remote filter #1028
5. Hose, Braided Stainless Steel, -8 AN, 10 ft. Length, Each
http://www.summitracing.com/int/parts/sum-230810/overview/
