inkjunkie
You always read how a HEMI cost so much more than a wedge to build. Thanks to my latest bout of insomnia I have done some #s crunching, and while the HEMI did indeed come out on top $$ wise, it was not as bad as I thought. Keep in mind I am talking a like for like build. Not a used wedge block compared to a new HEMI block. So seeing as how, for argument sake INDY charges the same for a Aluminum Wedge Block as they do for the Aluminum HEMI block, likewise for the Iron version that is not a factor. Neither is anything else in the bottom end, same price on crank, rods, pistons were slightly more for HEMI, oil pan is the same etc. The difference was in the top end. Now sure, you could say run a set of used iron heads on the wedge to save some money. But remember like for like. And lets say the displacement for both was going to be 572. From what I have read a Max Wedge port is needed at this size of a wedge. Went to HUGHES to get a price for a set of cnc ported MW Victors. With valves they were $2800. A set of Stage V heads, from the numbers I have found, this is ported with valves is $3400. Really not that much of price difference. The valve train, well that is a bit different. Sure, you could get a set of inexpensive rockers from HUGHES for $550 but they are not in the same league as Stage V rockers with KB stands & shafts. So if you get into something a bit more realistic for a 572 Wedge, say Harland Sharps, the price is $1200. From what I have figured the Stage V rockers, Keith Black stands and shafts are going to come in around $2700. So far the difference in dollars is 2100. In my case I have a set of Valve covers for a HEMI, granted someone scratched them up on me and they need to be re-finished but I still have them. I also have an intake for a HEMI, a crossram set up for EFI, complete with fuel rails and throttle bodies. Am I missing something here on the $$ end of the HEMI vs. Wedge comparison? I realize there is a lot more to it than this, but
Suppose it would be helpful to ad that, lets say, 750-800 hp would be a target....So if I am way off, someone please enlighten me.....:happy1:
