money does no good at that point.($$$$)
If someone would make a W2 style head for the big block, that would level the playing field.
Even with a B1 you won't do it, diminished return. and why is that?
Probably head flow I don't know what those W8 heads are producing flow wise but kind of easy going from stock 200 cfm to aftermarket 300-350 cfm making 1.9-2.3 or so hp per cfm 550-800 hp but imagine gains get exponentially harder and expensive above that.Even with a B1 you won't do it, diminished return. and why is that?
No. A Hemi head is. That's the big block W2, IMO.It’s not really big enough. A B1 is the minimum head that should be on 470 inch and bigger engines.
Probably not with Shilo's. lolWon’t do what? Run with a small block?
mid 8's letting off. Down right nastyWhat’s he running now? I haven’t seen what he’s been up to lately.
We can fix that.The Hemi flows enough air but NA it sucks.
Other than outright air flow, the Hemi doesn’t do much NA.
There is more to making power than airflow.
StageV Engineering made HEMI conversion heads for B/RB's, NRE was just on this site what,..a month & a half ago talking about the Predator heads..like 470cfm ootb & mid 500's well ported, plus NRE had the Covalt 32V conversion for $10K in the 90's..the whole kit intake, heads, valve covers, pushrods, all You had to furnish was a HEMI pattern cam & headers....crickets. The only heads that went anywhere were the B1's, mainly due to Alderman/Geffrion's seasons running them, the publicity & wins sold them.No. A Hemi head is. That's the big block W2, IMO.
Do you even read what I'm posting, I never claimed larger piston just magically makes Hp, I've said that repeatedly in this thread, we've been talking about force and torque, you keep saying if larger pistons apply more force to the crank its free Hp which is wrong and I've explained why a bunch of times.OK,
Back to the topic. I should have been more specific.
Waaaaaay back in another thread, 273 claimed that a bigger piston made more hp because of the increased area. The extra area created more 'push'. Not on it's own. There is a sequence of events that occur to make this happen. The increased area allowed more air to be drawn in to the cyl, & the extra air & the increase in compression pressure generated is what pushes the piston down. The bigger piston area was a means to get more air into the cyl [ just like increasing the stroke does ]. If no more air was drawn into the cyl for some reason, then no more hp would be made with the larger piston.
You think you have, far as I can tell no one has agreed with your take now that doesn't automatically make you wrong but It should probably give you some pause to your confidence of being so sure your right especially with the arguments you've been using.I don't how many examples are needed, I have given heaps. 273, you know I am correct, it s a pity you haven't got the guts to admit it.
This isn't a great analogy to the combustion pressure (psi) on a piston, again f=pa which pistons force is equal to piston area x combustion pressure psi, you don't need all these analogies that don't represent well what's happening.Here are yet more examples:
[1] You centre punch a piece of alum, which leaves a depression in the alum. You then get a punch with a flat bottom & hit it with the same force. There is no depression in the alum because the force is spread over a bigger area; the bigger area of the flat punch did NOT give a deeper depression.
I get what you saying here and maybe someone with a better pay grade can explain it, (i got a good idea why), like I've said in how to prove me/us wrong post you would have to prove the combustion psi would be significantly different basically equal to the difference to the piston area.[2] You are going drag racing with your Dart. You are going to replace the skinny 5" factory wheels/tyres with slicks. The contact area of the tyre/ground goes from 15 sq in for the factory tyre to 30 sq in for the slicks. Weight on the wheel is 800 lb; tyre loading on the ground with the 5" wheel is 53 lb/ sq in. Using 273 'logic', the extra area of the slick[ 30 sq in ] & keeping the same 53 lb/s in but spread over the bigger area....would require 1600 lbs of weight...when you only have 800 lbs. Totally wrong as you can see. The correct answer is the loading on the slick is 26.5 lb/ sq in, not 53....
Stage V is still kickin.StageV Engineering made HEMI conversion heads for B/RB's, NRE was just on this site what,..a month & a half ago talking about the Predator heads..like 470cfm ootb & mid 500's well ported, plus NRE had the Covalt 32V conversion for $10K in the 90's..the whole kit intake, heads, valve covers, pushrods, all You had to furnish was a HEMI pattern cam & headers....crickets. The only heads that went anywhere were the B1's, mainly due to Alderman/Geffrion's seasons running them, the publicity & wins sold them.
The Covalt setup made low 800'sHp w/a freaking 280° cam,....no takers, everybody skeert....it's amazing anybody builds B/RB Mopar stuff today.
I was hopin' so, any RB can be a HEMI with stuff already there, it was a great idea.Stage V is still kickin.
When it comes to displacement, no.There comes a point of diminishing return
Gotta disagree. Bigger pistons and longer strokes draw in more air (and fuel). Changing bore/displacement changes compression ratios in a given engine, and that's widely known.But what we do know combustion pressure (psi) is based on efficiency not displacement.
This is at the edge of my understanding of this so I'm not saying I'm a 100% right but to me the more fuel and air is in relation to the displacement difference, so at say a 100% ve and 10:1 cr a 25 cid cylinder vs a 50 cid cylinder the 50 cid should have about twice the fuel and air but has twice the compressed volume and expands to twice the total volume which I'm guessing theoretically should create similar psi.When it comes to displacement, no.
Compression ratio is a determination of potential pressures, all else being equal. Increasing, for example, the bore, increases the amount of air/fuel drawn in, by the swept volume. This is in greater proportion to the combustion chamber volume (which also increases, but not as much).
So, increasing displacement does increase combustion pressures, all else being equal.
Imagine that........Maybe you could tell us how we go about creating and enhancing these "Efficiencies"But what we do know combustion pressure (psi) is based on efficiency not displacement.
It's more efficient to ignore youImagine that........Maybe you could tell us how we go about creating and enhancing these "Efficiencies"
Can you fit that in a Dart? No. So there's your diminished return. lolWhen it comes to displacement, no.
