michformulaS
Billet time chain set $90
Custom grind cam at 236 @ .050 $211 shipping $15
chrome moly retainers $56
mopar valve locks $45
balancer $136
narrowed rod bearings $72
narrrowed main bearings $112
shipping $9
dist shaft bushing $10
dist shaft $70
416 rotating assembly (4340 and forged KB's) $1550
shipping $90
bronze liners $40
machine caps and align hone $155
engine assy. $600
internal balance dynamic $220
torque plate hone $90
degree cam $45
gap rings $60
install bronze liners and hone fit $108
milling head/clean up cut $80
machine valve guides $40
teflon valve stem seals $24
port heads $300
check install valve springs/check tension/shim $35
valve job $225
magnaflux block $55
environmental charge/waste $10
valve springs $99
plasma moly rings $115
gasket set $65
roller rocker kit with shafts $470
air gap manifold $270
paint $14
misc shippng $25
lifters $97
0 deck block $140
high volume oil pump $56
head bolts $63
fuel line for Demon $39
fuel pump $94
2800 stall torque converter $360
intake bolts $23
oil pan bolts $13
Demon 750 $466
MSD 6AL box $220
misc shipping $12
spark plugs $22
intake gaskets $19
push rods $128
fuel pump eccentric $17
timing cover $90
dipstick tube $11
misc shipping $11
rocker hold down retainer kit $34
crank bolt $12
oil pickup $45
deep oil pan $240
washer and bolt for fuel pump eccentric $19
oil slinger $11
valve covers $55
12 point stainless bolts (intake) $22
pan bolts $26
header shipping $26
thick valve cover gaskets (keeps rockers from hitting moroso covers) $43
hooker headers $460
camshaft plug $3
motor mount $16 (need a torque strap these are like jello)
fuel line and heater hoses $45
breather $10
trans lines $18
engine break in add $15
oil filter $15
case of 30w racing oil $54
trans fluid $21
anti freeze $28
install oil pressure gage and wire $25
mount MSD box $25
install engine $350
service trans/pan/filter/gaskets $50
header labor $50
trans lines/cooler labor $60
bushings $7
oil pressure gage $27
pipe nipple $5
air filter $12
MSD distributer $260
misc return -$50
boot/terminals kit $12
ignition tuning labor $20
trans gasket $10
This is the the bulk of the parts, labor, and install of a 416 into my 68 Formula S 340. I supplied a bare bored 0.30 block and some X heads that had been rebuilt by a supplier that used to advertise on this site that supplied me with supposedly rebuilt heads for about $700. The original work was very sloppy on these heads with large valve clearances and cast bushings. I have about $11000 into this motor and install. There was a significant oil leak when I first drove it 20 miles. Rick came to me with his race trailer (70 miles). Fixed that oil pan leak and a small main seal leak which was rectified by drilling a couple relief holes and opening up the rear main cap. Still runs 60 - 70 psi warm. He brought it back to my house in his trailer. Rick LaPoutrre (racingengines.com) is a stand up guy. Takes a while but his work is not hurried and perfect and he stands behind everything he does. Bay City Michigan. I just hope it stops raining this weekend so I can stand on this thing! Thanks Rick!
balancer $136
shipping $9
dist shaft $70
shipping $90
bronze liners $40
engine assy. $600
degree cam $45
gap rings $60
port heads $300
valve job $225
magnaflux block $55
valve springs $99
gasket set $65
paint $14
misc shippng $25
lifters $97
0 deck block $140
head bolts $63
fuel pump $94
intake bolts $23
oil pan bolts $13
Demon 750 $466
MSD 6AL box $220
misc shipping $12
spark plugs $22
intake gaskets $19
push rods $128
timing cover $90
dipstick tube $11
misc shipping $11
crank bolt $12
oil pickup $45
deep oil pan $240
oil slinger $11
valve covers $55
pan bolts $26
header shipping $26
hooker headers $460
camshaft plug $3
breather $10
trans lines $18
oil filter $15
trans fluid $21
anti freeze $28
mount MSD box $25
install engine $350
header labor $50
bushings $7
pipe nipple $5
air filter $12
misc return -$50
trans gasket $10
