RedScampi
Joey came over and we set the engine and transmission in last night. 8) :cheers:I had the headers held in the bay with wires and we lowered the engine in between them. It took about 20 minutes, tops. I still need a trans crossmember before I can finalize the position but I will say that the driver's header is resting on the side of the oil pan at the moment and there is almost no room even for a gasket on that side. :sad5:I'm sure we'll have to do some shimming and wiggling to get it all working together. Oh, and I need a straight power steering inlet pipe thingy rather than the 45 degree one that is on there now so the hose won't run too close to the header.
