pishta
I know I'm right....
Ill call it "the bead-eater"....peeled 4 old tires off my ralleys to put on my pickup (my tires were bald and a belt broke) Ralley Tires didnt have more than 1000 miles on them but they were >15 years old in a garage and 2 were flat for almost as long with a car sitting on them. So I mount this on the bed of my truck, bolt it down as required and go to work. truck tires come off as designed. Breaker shoe on lever works fine, could be at higher angle so the bar doesnt hit the rim and still not undeat the bead. It was hard as hell keeping the bead in the small of the rim as I pried up the opposite side and pulled the breaker bar around. LUBE LUBE LUBE! whatever you got, Go-Jo, WD40, Dawn, motor oil! peeled them off with huge amounts of sweat from me as I dont do this..ever. So now I start breaking the Ralley tires, first one has nice crack in sidewall but comes off pretty clean, one small chunk of inner bead comes off, doesnt affect seal. Next one comes off harder, I get a few chunks of bead shaved off by the bar, looks sketchy but still holds air. I grind the sides of the bar down so they are not at a 90 angle, more of a 45. 3rd and 4th are ugly, I get huge tears in the bead, so much as to ruin the last one as it wont seal now. OK, 2 new tires are being bought, mounted and balanced.
Putting on the tires is a mystery. I cant get the bar to pry the lip over the rim no matter how many times I watch the youtube @ minute 12:30)-- [ame="https://www.youtube.com/watch?v=bUas5LIY_ok"]HF Tire Changer - YouTube[/ame]
--of the same tool (mines cheaper model with no tool storage) being used by a pro. His tires look so soft compared to mine my sidewalls would not flex that much no matter how hard I tried. I resort to the old tire irons, prying the tire over the rim small bites at a time. Works but is kinda scary as you think your going to snap something, the bead cord or the tool! you know, for $12 to mount and balance a tire at the corner garage, Ill pay that all day instead of using this tool again, and my back still hurts! Ironic that the old truck tires never shed any bead material, I think the old Ralley tires were rotted. Bonus is it looks like a red machine gun mount in the back of my pickup as I drive to work with it still mounted.
