AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 24,989
- Reaction score
- 12,339
That chuckle is worth a like any day,lol.
I would say farm truck is a stretch . But yes it has a np435 in it right now. It doesn’t do work, but it also is not a strip truck either. It’s a driver, it gets driven, whether is to the store or a car show or to my job. so I am back to thinking .038 head gaskets and maybe try to get the heads to 65cc by enlarging the chamber on the edge of the bore. Maybe jump up to a 276 Lunati.
@nm9stheham and @AJ/FormS last question, for today . Better to get the bigger Cam, Lunati 276, and keep a 1.5 rocker ratio or get the smaller Cam, Lunati 268, and get 1.6 rocker ratio? I think with the 276 cam and 1.6 ratio I am right under the limit for the stock edelbrock springs.
It's all about torque fall off when you shift
calculate the % rpm drop 2-3 and 3-4
me if these are forged pistons I'd send em to Texas and have them dished (I'd do it myself)
see if whoever is going to tune up the heads (check the guides for tight and maybe give them a better concentric valve job ) can open up the chambers
use the thinner gasket- anyone else used another but Edlebrock's gasket- and since Edelbrock does not make gaskets whose is the cheapest gasket they were able to find?
I'd rather have a little more compression and a lot tighter quench - but that's me
My gut tells me the 268 Lunati cam with the 1.6 rockers on the intakes only would be max for that truck trading broad torque band for a little top end HP
If it was me I'd call Rick Jones at Controlled Induction and see how much he would charge to run the numbers for you- have your head flows handy, see how he adjusts for altitude and the other things that make your build sorta special- like the 3 speed
any chance on running a sft?
cheers
let me know what he says
Which is perplexing.... 'cuz I had a 10+ SCR at 160 psi cranking pressure (at 1000') iron headed 351C that I ran at 1000-2500' all the time, and no issues. DCR worked out in the 8.2 or so range, higher than yours.I would not "overestimate" the effect of the lower air density at higher altitudes here in CO, that lower density's effect on gas engines and detonation is offset by our super low humidity and high summer air temps. I had chronic pinging issues in my old 360 until it finally busted a ring land and cracked a cylinder; it was a 1975 360 LA block bored .060" over with KB flat-tops at zero deck, stock crank and rods, stock Magnum heads and rockers, Lunati Voodoo 256/262 adv. duration hydraulic FT cam (too small), Air-Gap intake, shorty headers... It measured out to 10.42:1 SCR and I had cranking compression only around 160 psi but on hot summer days even with fresh premium 91 in the tank and total mechanical advance of 32* it would ping like a mf'er if I opened up the secondaries in 2nd or 3rd gear (904 trans with 2.94 rear gears). This was when I lived in Denver, then the first year or 2 I lived in Fort Collins so the elevation was usually 5000-6000'.
I spoke to Racer Brown about a cam today. Jim also agreed that with the right quench, 11.25:1 wouldn’t be a problem. He is going to think about a cam with the right amount of lift and duration for the altitude.
Wym, the Wallace calculator works with an entered value of ICA, so I think the answer to your question is no, it just uses that as the termination point for pressure release via the intake. I think you may be thinking of the Comp calculator, which IIRC works from .050" and makes some assumptions of how much later the valve effective closes. FWIW: For the Wallace and Pat Kelley calculators, I typically put in advertised unless it is for a solid, where I adjust from advertised to try to account for lash.
I personally agree very strongly with the tighter quench gap. And I like the 1.6 rockers but my hesitation of putting them with a Lunati Voodoo cam is that you are putting more force on the valvetrain with an already fast slope cam. Where I really hesitate is at the lifter/lobe interface. I bet peak pressures on the lifters and lobes will go up by >10% or more, with the 1.6 rockers. You get a mildly exponential increase since the force is related not just to the lift ratio, but is also increased by the increased valvetrain velocities. That same applies to the Voodoo and XE types cams: the valvetrain force goes up more than many folks may realize.
We put 1.6 rockers in my son's 340 but it was with a milder ramped Crane 268 cam.
I did not realize your quench was that good.... .043 or so is decent.Nice, I think I'll call him for my cam too, that's reassuring he says it will work. I wouldn't be surprised if the quench was off the mark in my past build, I used .039" head gaskets but didn't go through the full process of making sure each piston came up to zero deck. I only measured #1 and it was still .003-.005" below, the rest may have been more or less as my machinist said the block had already been decked but not square-decked. Also I later checked the accuracy of my Harbor Freight compression tester with my air compressor and it was definitely reading low by maybe 20 psi at 150 on the compressor gauge so I think the actual compression was higher. @nm9stheham the Voodoo cam I had not only has 'fast' ramps but is ground 4 degrees advanced from the factory and is advertised as being intended for smaller-displacement engines with stock/lower compression. I first bought the cam for the stock 318 the car came with, I was dumb and wanted to save a couple hundred bucks so I reused it (with lifters of course) in the 360. Sure had a sh**load of torque on the bottom end at least and it lasted maybe 20k miles even with all the pinging.
Sound very promising. I'd like to hear about the specs and the ramps in particular.I spoke to Racer Brown about a cam today. Jim also agreed that with the right quench, 11.25:1 wouldn’t be a problem. He is going to think about a cam with the right amount of lift and duration for the altitude.
Have you ever considered a turbo? Wide torque curves are its specialty. You could shift at 5000 bringing it down to 2500 and immediately have full boost.
