YoungBlood
Jolt the Squares
It's not likely that a high volume oil pump would suck a stock oil pan dangerously dry, but if I added a windage tray (and valley pan per-say) wouldn't that not only help with a little added power but also help get oil back to the sump rapid-like correct?
The 8 qt. moroso street/strip pans are $215 and are really sweet, but DANG do they hang low and a good windage tray can be had for $70-$80.
Or is a windage tray necessary with a HV Oil Pump and stock pan? (assuming the car is driven a lot)
