If the head is...? a 340/360 head and it has been shaved that far.......then you have TWO problems.
One, as mentioned, the gasket material is way to thin on the head, and WILL crack. Destroying your eng.
The 2NT problem is the intake! you will have to shave A LOT off the intake manifold just to get it on. You don't know how much was shaved off the head so you don't now how much to take off the intake surface.
There just something, that don't look right, there. IF its not a X, J, O, Exc. then well that's why it looks strange to me......
This is what's been running threw my head.
Is it possible, that if it is a 340/360 head.......that the deck has been angle milled?
This would give the closed combustion chamber appearance with out being so thin?
There just seems to be to much deck surface on the long side or, the spark plug side.
Here's a pic of my 360 head.
