mopar56
When rebuilding a holley 600cfm 1850 and replacing the fuel transfer tube seals the holley kit comes with o-rings and seals, what is better o-rings or the seals? Or dose it matter?
Filling the carb doesn't do much... They are on the pressurized part of the fuel system, outside the float bowls..Ok, I didn't actually see the seals or know what they were for until I was searching the net after, I had only noticed the o rings and used them, I did roll them down the tube but I used some soapy water so they wouldn't pinch, I suppose I could pre fill the bowls with fuel thru the vent tube then tilt the carb back and forth to look for leaks? Failing that, remove and install the other seals.
We're doing carbs here... Not ****....I use spit to lube them up. Always readily available. lol
They worked well for a really long time.Well I think I'll just leave in the o-rings, and see how it goes, worst case I change em out! Confidence is high! Lol
