Duggie
I'm cleaning the shop after upgrading to a BBD on my /6. For Sale is a Holley 1920 that came with the car when I bought it. It was stickered UREMCO Remanufactured 01/29/15. Looking at previous invoice history, I'm guessing the carb has less than 5K miles on it. I put a rebuild kit in it along with the factory spec main jet, and installed the missing float baffle thanks to the generosity of @RAT ROD AL. I also adjusted all linkages and float to factory specs. I think the float weighed 1/2 gram heavier than spec. Included is the spare parts from the rebuild kit, the larger main jet, and a new cork float cover gasket. Also included is the heat well choke spring.
I'm happy to take close up pics of anything you want a better look at.
$100 plus the stamp from 98418.
