Bugman
Will I run the charcoal canister line to this port? No goes to pvc valve
green arrow is pcv port, do gasket and manifold hole match or did you notch gasket
Ok looks right. What year car and can you take picture of vacuum canister, two different ones,with and with out control valve. Is going to say to carb bowl vent. Your carb bowl vent is to open air no hose fitting. So on canister bowl vent conection just cap it
Funny you bring that up! I actually just got a new one. Lol Thank you for noticing!Uhhh, I have to ask, per pics in posts#16 & 24.....why is there no throttle return-spring on the throttle? Really should use a dual inner/outer set. Yet there is a throttle spring on the choke link clip? That's not going to work well for either!!
I had considered that, actually. I was concerned about the potential consequences. I may give that a shot when I get home from work.No purge port or maybe it does. For the sake of discusion why not run purge line from canistor to anti ice system port. Carb does not know where air comes from, have to think about that
