As title states. Has a fresh accelerator pump diaphragm, stock jetting(72), and stock power valve(6.5). Works great! Used to use it for test carb. Haven't used it much the last couple years. I had the bowls off and all is good and clean. Shafts are right and tight. Bolt on and go. $200.00 plus the ride. PM me here. Thanks, FABO!!!
