Holley 650 dp Blow Through Carb and 750 Main body
AnotherA
Mn
Holley 4777 carb ( 650cfm double pump) setup for blow through.
Was used on my 318 with ~7lbs of boost.
I ran it with the 650 main body and then moved up to the 750 HP holey main body instead of cutting the choke horn off to fit the carb hat i had.
It ran good, didn't have any problems with the carb.
No longer need it since I'm going back to an NA motor.
Fuel level sight glass
Center hung Nitrophyl floats - Won't collapse under boost.
Jet extensions
.120 Needle and seats
50cc accelerator pump
Power valve channel restriction drilled out to 5/64".
All the hanger18 mods to the carb can be found here.
http://www.hangar18fabrication.com/blowthru.html
Carb $350 + shipping
HP main body SOLD
Located in MN.
HP main body is SOLD. Thank you CUUDAK!
Carb is still available.
