Hyper Henry
Holley part #90670-2; just rebuilt and ready to go. Carb is designed for off-road truck use but can be used for any application. $200 usd and I will ship for free anywhere in the US or Canada. Prefer Paypal but will take cheque and ship when cleared. Located in Ontario, Canada.
Info from Holley:
The Off-Road Truck Avenger is designed specifically for off-road applications. The unique fuel metering block eliminates fuel spillover through the boosters at extreme angles allowing for 40 degree climbing, 30 degree side hill maneuvers and nose-down descents to avoid hesitations, stalling and flooding typically associated with carbs in an off-road environment. The Truck Avenger features a quick change vacuum secondary for easy fine tuning; four vacuum ports for all necessary vacuum accessories; factory preset electric choke for easy start ups; and a built-in fuel filter. The 670 CFM Off-Road Truck Avenger is the perfect carburetor for small blocks or stock big block engines.
Info from Holley:
