JoeDust451
- Joined
- Jul 1, 2005
- Messages
- 1,348
- Reaction score
- 27
Sent you a PM
It doesn't seem to matter what speed I'm going if I'm easy on the throttle it will go threw the gears and drive like normal. Wether at 5mph or 20 or 30 if I lay into it it spits and pops through the carb. But when I'm sitting in my garage I can snap the throttle and it's clean and crisp.
Cam timing shouldn't be a issue right? Especially if it revs in park good. ?
Yes I'm running a ballast resistor.
I'm gonna buy a new coil and test it out I heard they can work ok but act funky under a load.
Nope the cams straight up dot to dot. Readings were with my edelbrock dual plane. If that means anything lol
