just done a tune up on my 416. rpm heads air gap intake 10.03- 1 compression. cam is 543 lift dur at 50 is 256 lobe sep is 110 and 106.1. msd 6al and a msd dist.the carb is a 950hp primary jets are76 and sec jets are 75. air bleeds are 74 idle and 32 primary.the car is working good I just want to clean my idle up a bit she burns the eyes a bit at idle how much bigger air bleeds should I try. go up to 76 or go up higher. what are u guys running for air bleeds in your strokers with the 950 hp
