7 70orangeswinger Well-Known Member Joined Oct 25, 2008 Messages 345 Reaction score 21 Location northcentral PA Sep 23, 2011 #1 Where can I find the #'s on a duel feed double pump Holley carb?
Mrmopartech Well-Known Member Joined Jun 5, 2005 Messages 2,149 Reaction score 90 Location St.Lazare Quebec Canada Sep 23, 2011 #2 On the air horn where they all are,(choke housing) mrmopartech
chasduster Well-Known Member Joined Sep 17, 2008 Messages 2,172 Reaction score 34 Location California Sep 23, 2011 #3 I think they are on the driver front of choke horn.... don;t quote me though ooh oopps you beat me too it
Jonny H Well-Known Member Joined Aug 20, 2011 Messages 81 Reaction score 2 Location PDX Sep 23, 2011 #4 look on the air horn
Jonny H Well-Known Member Joined Aug 20, 2011 Messages 81 Reaction score 2 Location PDX Sep 23, 2011 #5 check here when you find the numbers http://www.holley.com/data/TechService/Technical/Carb Numerical Listing.pdf
C crackedback FABO Gold Member FABO Gold Member Joined Aug 7, 2005 Messages 19,183 Reaction score 5,929 Location 92201 Sep 23, 2011 #6 So they are ALL on the choke horn? How about this double pumper? oops no choke horn on that one. If it has a choke horn it should be there. It will usually say list-xxxx or 0-xxxx something like that. then use the holley link listed by Johnny H
bad440 everything,all the time.. Joined Mar 27, 2010 Messages 3,646 Reaction score 177 Location oakland ca Sep 24, 2011 #7 do the metering blocks still have the list # on them ?my old 750s are stamped 4779 on both
C crackedback FABO Gold Member FABO Gold Member Joined Aug 7, 2005 Messages 19,183 Reaction score 5,929 Location 92201 Sep 24, 2011 #8 bad440 said: do the metering blocks still have the list # on them ?my old 750s are stamped 4779 on both Click to expand... Yeah those are 750 dp metering blocks. Not all have a list number on the blocks
