holley choke fit demon carbs??
dodgefreak8
Hey everyone I bought a 575 speed demon carb for my 86 dodge w150 and I HATE the choke! It doesn't have a vacuum pull off and if you leave the truck off for 20 minutes the choke closes again and the truck runs like hell until it opens. So I was wondering if anyone knew if a holley choke will fit a demon carb??
Sounds more like a choke adjustment on the houseing side to a leaner position. The actual mechanical part, the housing may fit. See if you can borrow one from a freind to test fitment.
if I lean it out more it opens to quickly for the cold starts here in colorado
