yellow rose
Overnight Sensation
Go back to the 31 nozzels and swap the red cams for blue cams.
https://documents.holley.com/99-41141-100.pdf
Do you like the blue cam on the primary and secondary or just the primary side??
Both. Also blue cam works better in #1 screw hole IMO.Do you like the blue cam on the primary and secondary or just the primary side??
IMO I think you have a case of too big of carb. If that's an 850 Mighty Demon it has 1.56 venturi with a 1.75 thottle bore base plate. Essentially the biggest combination Barry Grant offered in a 4150 style carb from what I know. On the flow bench that thing will go 1000+ CFM. That carb is better suited on a 450+ cube motor. Its going to be a finicky temperamental bastard on a 408. You may also be lean as that carb should have 85/93 jets, this could be why you have a stumble.
Looks like it has too much emulsion as well. .031 is pretty big and there are only two plugged.
Are the check valve needles in place under the squirtter nozzles ? IMO the spray pattern doesn't look bad. Things I'd try jet it up to factory spec and re drive it. Spray carb / brake cleaner around look for vacuum leaks. Try other carb, see if it runs good.
Especially with someone that understand just enough about it to ruin a Carb!Its the holes in the metering block that intersect the main well channel. If they put too many or too large of emulsion orifices the fuel curve through the rpm range can be wonky. Personally I like Holley's old school calibration 2 E holes .028 in size. You have to have a wide band to see if your AFR is doing weird stuff to get a handle on trying to tune them. Best left alone.
bump the video to 1:10min mark
Sorry i misread that earlier, yes the check valves under the squirters are in place.Are the check valve needles in place under the squirtter nozzles ? IMO the spray pattern doesn't look bad. Things I'd try jet it up to factory spec and re drive it. Spray carb / brake cleaner around look for vacuum leaks. Try other carb, see if it runs good.
