PRH
I thought this was a pretty good little video:
qf q series come with 4x.028
noAre you counting the siphon break as an emulsion hole?
I haven’t had a Q series apart in ages..... can’t remember what the emulsion looked like.
If your ordering parts make sure to get a power valve plug for the rear, along with the notched float and jet extension kit. Also make sure you have those plastic vent baffles/whistles on both blocks. Another thing to verify is that the bowl vent tubes are not up tight against the air filter lid.
Must be a misprint on the 148 main jet. Hope that's not correct. That's an alcohol jet.
Spray all the orifices out with carb clean, and use your current jets when you install it.
so i when out to get the metering block off of my 3310. Its not a 3310 its 1850 that i put the duel feed fuel bowl on.
I jumped on ebay and found another block that is for a 3310 and bought it.
will a 1850 work? i have 2 of them.
I also have a list #6160 carb that was holley original equipment on a 383/440 (1850 design)
Don't really want to disassemble that 6160 as it was the Best carb i ran on my 340. Way better, than its look alike 1850.
So i start to do some research. So that i can buy a spare metering block or maybe 2? There or a LOT OF METERING BLOCK on ebay that only have the stamped # on the metering blocks that has nothing to do with the list# (3310) or the metering block # 134-131) I can't seem to find any info out there to cross reference the same number on the block with.......well with any thing.
the stamping are numbers like 11761 or 7492 or even a 6909 8101. That last one the claim is for a 72-74 dodge..........dodge what? carb what? I don't know.
I have 2 metering block coming my way that are sapoaby off of a 3310...........how the, bank-it-e-blank do i know that's what they came off of?
