holley double pumper id?
340plot
the bushy bush
va
My Car Has A Holley D.p On It, And I Can't Find A Number On It. It Is Leaking Gas Out Of The Shaft That Works The Throttle Cable. Are These Hard To Rebuild? I Am A Novice At Carbs. Or Should I Find Someone That Will Rebuild It For Me?
Well… You need to find some numbers or take some pics. If it is leaking around the throttle shafts that wouldn't be a standard novice at home rebuild.
Some of the other guys will give you your options.
Dirt, float level too high, sunk float.
It's dripping fuel into the venturi from the booster. The fuel level is too high in your bowls.
Got a picture of the carb? If it has a choke horn on it, the number will be on the front edge of that, more than likely.
numbers are 4779 and other num,ber is 6541. now is there anyone that will rebuild it for me?
