I bought a Holley sniper EFI kit with the fuel system included. I ended up going with a Holley in tank fuel pump instead. This pump I have for sale will work for most aftermarket throttle body EFI systems. I have the unused pump with mounting brackets and the Wix pre pump fuel filter. I also have the bulkhead and related fittings to put a return line in your OE tank.
The only thing you would need for the fuel system is EFI rated fuel line and clamps.
Holley charges $365 for the complete kit and charges $135 for the pump by itself.
I have also used this same pump in the past with a "Corvette" filter/regulator on a 5.9 magnum swap using the factory EFI with great results.
I would like to get $100 shipped for the pump and fittings. I'm located in Oklahoma City.
