Holley eletric pump sometimes louder!! Like bad loud??
Fuel and Air Systems
  1. 340Duster247
    340Duster247 Well-Known Member
    832
    273
    Dec 5, 2012
    Calgary
    Local Time:
    10:42 PM
    So I just got the duster together and dialing it in.
    Running a holley black eletric pump deadheaded to regulator. When the car is cold started the pump has a normal holley buzz/ noise that is fine.
    But sometimes when I restart the car after sitting ( engine still hot) I get a horrible High pitched whine from the pump.
    Also EVERY time after I put gas in the tank, it does the same noise untill a couple mins down the road.
    I'm running factory tank- 1/2 line to pump- 3/8s to filter. -6 to regulator ( dead headed) -6 to carb.
    I'm running no filter before the pump right now cause I thought it was a cavitation problem.
    And ideas. ??
    Sounds like a run over cat!!
  2. Fisher
    Fisher Old Guy with a Cool car.
    1,951
    920
    Jul 22, 2012
    Regina Sask Canada
    Local Time:
    11:42 PM
    I have never liked Holley pumps, the ones i have had, have failed. It's my rule to never dead head an electric pump, i always run a return line. Sorry i cant be more helpfull,but heat will kill an electric fuel pump.
  3. Fisher
    1,951
    920
    Jul 22, 2012
    Regina Sask Canada
    Local Time:
    11:42 PM
    The other thing i forgot to mention, is i am not sure that the holley elec pump is designed for "continuous" use. I know the Aeromotive pumps had a 400 hr life span to them, that was years ago, i am sure that has been addressed. Barry grant pumps had all sorts of issues as well.
    When i had my camaro, i had an SX pump on it, was designed for 1000 hp and continuous use. It took a #10 feed and an #8 return line, that hurt the pocket book. But that pump is still on the car after 10 years no issues at all.
  4. 340Duster247
    832
    273
    Dec 5, 2012
    Calgary
    Local Time:
    10:42 PM
    Yah I'm thinking of doing a return style regulator. But wanted to ask you guys first to see if I'm missing anything.
    Thanks
  5. 340Duster247
    832
    273
    Dec 5, 2012
    Calgary
    Local Time:
    10:42 PM
    Didnt wanna waste the money on a return style and then have nothing change
  6. Fisher
    1,951
    920
    Jul 22, 2012
    Regina Sask Canada
    Local Time:
    11:42 PM
    Holley's are noisey, the vanes stick inside they cavitate, just a poor design in my opinion.
  7. Fisher
    1,951
    920
    Jul 22, 2012
    Regina Sask Canada
    Local Time:
    11:42 PM
    Base the fuel pump you need on the GPH the motor requires. Things change when you get to the track, or you get the car too hook. Now the pump has to work against the Gforce as well, some pumps cant keep up.
  8. pishta
    pishta I know I'm right....
    19,882
    9240
    Oct 13, 2004
    Tustin, CA
    Local Time:
    9:42 PM
    the high pitch may be from air pockets. I had a blue (with regulator) and it ran funny until it was solid fuel in the line. I could tell when the carb filled when the pump dropped RPM by like 1/2. And it was loud too, not black loud but noticeable. My Red leaked and I couldnt rebuild it for less than a new one. I would rather run a Walbro style inline with a big return line now, quieter, higher volume and they are available off Ford truck frames at the wrecking yard. Keeps fuel cool too as it recirculates/filters it constantly and keeps your tank clean.
    • Like Like x 1
    • green1
      green1 Well-Known Member
      4,668
      19
      Dec 6, 2008
      Orange Park, Fla
      Local Time:
      11:42 PM
      What year trucks?
    • Hemioutlaw
      Hemioutlaw Make America Great Again! FABO Gold Member
      1,286
      747
      Feb 4, 2014
      The Great State of Texas
      Local Time:
      11:42 PM
      Ran the Holleys on a street car years ago and went thru a few of them, the damn case kept cracking and since they are made out of cheap pot metal we couldn't even weld the cracks. Finally Shitcanned the Holleys and started using Carter Competitions I am only on my 2nd one of them after many years of use. They do tend to be on the noisy side though and I will probably look into something else when this one takes a dump.
    • 67Dart273
      67Dart273 FABO Gold Member FABO Gold Member
      48,351
      16374
      Oct 14, 2010
      Idaho
      Local Time:
      9:42 PM
      So, you are running a regulator without a return line? This is a great way to promote cavitation and vapor lock, as the pump cannot maintain a constant flow through the pump. If the pump is much larger than the engine requires this can be greatly aggravated.
      Also, just pumping fuel heats it up. "Pumping losses."
      Any chance something is restricting the inlet?
    • RustyRatRod
      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
      71,976
      47195
      Jun 7, 2010
      Georgia
      Local Time:
      12:42 AM
      All of the red blue and black pumps suck. They are loud as hell even with a return. Look at the Holley 12-125 0r 12-150 if you want a quiet pump.
    • nm9stheham
      nm9stheham Well-Known Member
      12,090
      3956
      Dec 20, 2013
      Waynesboro, VA
      Local Time:
      12:42 AM
      Had the same problem with a Holley years ago....noisy as could be until we got the car up to speed racing and then it would quiet down. Concluded that it was air/cavitation. Changed to the old AC farm pumps; was fine on a small engine.
