Help; I switched over to a four barrel intake and carb on my 318. I bought a brand new holley 4160 600 cfm. I used it to break in the cam and every thing went well. Now it is leaking between the front metering block and when I shut it down it dumps fuel down the primaries for a few seconds. I know 4150 models well, but not these carbs. I would go after the float, but there is no float adjustment. One thing I should probebly mention is that when I was starting up I was still trying to get timing right, so I was moving the distributor and backfired up the carb twice. does this carb have a power valve and, or did I blow out the metering block gaskets? WTF with the float adj, do I have to remove the float bowl.
