turbofreek
batcrap crazy racing team
I just found that holley has the hp efi available for the newgen hemis. Plug n play for about 1500 bucks. Its a great system with some data logging but clearly not as expensive as the dominator but its about 800 bucks cheaper. No boost controller but boost friendly. Will run the coils as well as far as I know.
After so much debate and parts buying and selling. I will likely go this route for the money. If need be ill add a data logger later anyways if I need more data for strip tuning. Currently it will log the major important stuff for a turbo car I will need.
Just wanted you guys to realize the hp efis potential as an option for you not so needing the top dog efi and want a bit more customer base besides diy on your own alone.
